Repair guides for the MacBook.
3786 Questions View all
Can't put LCD bezel in place...very hard!
Hi,
I'm trying to solve a blinking problem in my MacBook. It seems like inverter cable broken. I opened it to try to fix it before buying a new cable. Now I'm having problems because I'm not able to put the bezel in place anymore because i can't put the tabs in place. Any tips to fit these tabs in?
Thanks in advance...
Score -1
Add a comment
1 Answer
Most Helpful Answer
Look at the image
http://s1.guide-images.ifixit.net/igi/AJ... All the tabs should be on the frame, not the bezel. They tip in at an angle. It would be ok to glue or tape them in place. If you use tape slit open the slots with a blade before trying to pressfit the bezel.
Support the case completely and start along one side, top or bottom work outward at the same pace. It's ok to squeeze hard on the bezel as long as you are squeezing the edge of the frame and NOT the LCD.
If this answer is acceptable please return and mark it.
Score 1
Add a comment
Add your answer
Eloy Fonseca will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,270
