Battery Connector Pad Removed :(
Hello,
before it happens, i experienced a lot of freezing then it reboots, until the firmware corrupted,
and then i tried to restore via itunes but i always got 14,2009, or whatever usb related issues
as i inspect it, i saw the battery connector that is loosen, so i tried to solder it myself, trial and error until the pad was removed.
now, my mistake, i trie to scratch it to the 2nd layer, i never knew that it is a ground, now, im messed.
my question is,
can i use my phone without gas guage and the ntc_conn?
can i use it if i just solder the ground and batt vcc
as shown in the diagram:
https://d3nevzfk7ii3be.cloudfront.net/ig...
and the damage i have done is like shown here:
http://s30.postimg.org/w598an8wx/image.j...
now my main concern is, can i use my phone if the gas guage is not soldered
and will it charge?
because the problem now is it seems it is not charging, and i cant restore to itunes due to interruption at the middle of the process.
thank you
