Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3202 Questions View all
Will the front panel assembly from an iPhone 5s work on an iPhone 5?
Hi, I see that the i5 and 5S have the same hook ups and same size will a i5s front panel work on a i5 phone? also if not will the face glass and white bracket work with it using a lcd screen of a i5? also if these will work then will the i5S finger print Home button work with the other two if they work? I love the face plate of the i5S the Gold Ring. Looks like to me that the i5S assembly will all fit to the i5 bottom assembly just fine? all the same connections and should line up perfect, please advise i need a new front assembly and I'd like to make it pretty and if possible work better. Thank you all, Terry.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
no screen connections are different so the connectors will not fit.
and no the home button will not work iphone 5 uses gold contacts for home button to work as iphone 5s uses a connection.
you can how ever buy home buttons that make the iphone 5 look like a 5s
Score 1
Comments:
ok, Thank you con.
by
Add a comment
Add your answer
workmanterry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 120
