How do I change the Sim place?
SIM does not work in my phone after falling into the water
abouryad, not sure about "Mobile machine drying clothes" but I would suggest you clean it properly before you have further corrosion damage. Use this guide to see how to clean the phone. The guide was written for an iPhone, but the same principle applies to your phone. Follow this guide to see how to mostly disassemble your phone. While you are cleaning it, take a look at the SIM card reader and see if you have any corrosion damage. It is also possible that you have a shortcircuit because of the water and corrosion damage. All that you should find out when you have it apart and cleaned. Hope this helps, good luck.
Guide
Difficulty:
Difficult
1 - 2 hours
Guide
Difficulty:
Moderate
25 - 30 minutes
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 205
2 Comments
what have you done to stop the corrosion after it fell in the water? What have you done overall to fix it?
by oldturkey03
I used hot air to be dry and then was run Mobile became the SIM show does not show and then was extinguished and placed in the Mobile machine drying clothes and then workman was not working SIM final.
by abouryad
