Released at 2013, September. Display size - 480 x 800 pixels, 4.3 inches. Internal memory - 4 GB, 1 GB RAM. CPU - Quad-core 1.2 GHz Cortex-A5, GPU - Adreno 203
18 Questions View all
How do I change the Sim place?
SIM does not work in my phone after falling into the water
what have you done to stop the corrosion after it fell in the water? What have you done overall to fix it?
I used hot air to be dry and then was run Mobile became the SIM show does not show and then was extinguished and placed in the Mobile machine drying clothes and then workman was not working SIM final.
Add a comment
1 Answer
Chosen Solution
abouryad, not sure about "Mobile machine drying clothes" but I would suggest you clean it properly before you have further corrosion damage. Use this guide to see how to clean the phone. The guide was written for an iPhone, but the same principle applies to your phone. Follow this guide to see how to mostly disassemble your phone. While you are cleaning it, take a look at the SIM card reader and see if you have any corrosion damage. It is also possible that you have a shortcircuit because of the water and corrosion damage. All that you should find out when you have it apart and cleaned. Hope this helps, good luck.
iPhone Image
Repairing iPhone Liquid Damage
Difficulty: Difficult1 - 2 hours
HTC Desire 500 Display Assembly Image
HTC Desire 500 - Display Assembly Replacement
Difficulty: Moderate25 - 30 minutes
Score 1
Add a comment
Add your answer
abouryad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 179
