Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Questions View all
drove with parking brake on & now will not shift
It starts fine and runs smooth but it won't shift. It has a THM700R4 transmission.. Put in a new speed sensor, would like to know what other sensors I might try?
Add a comment
1 Answer
Chosen Solution
kpgklm , How is your trans. fluid is the level correct(top up to proper level with correct fluid type if not), Does the fluid look dark or smell burnt, this would be a sign of warn parts/clutch packs inside transmission, possibly over heated from driving with park brake on. Other things could be plugged filter, collapsed/pinched trans lines, Trans. pan will have to be removed to check most, valve body plugged, bad/sticking governor/plastic gear(link#1), TV(throttle valve) valve stuck/ faulty(link#2), etc.etc.. If you do not feel comfortable diagnosing or working on the truck have a good Transmission tech. have a look diagnose and estimate repair. If estimate very high consider replacing trans. with a good used from an auto recycler. 3rd link is an article diagnosing GM transmissions. Good luck.
https://www.youtube.com/watch?v=PRdnl31q...
https://www.youtube.com/watch?v=WLfBZeOS...
http://www.lsxmag.com/tech-stories/diagn...
Score 2
Add a comment
Add your answer
kpgklm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 121
