Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Questions View all
Question Closed
What are the reverse steps for installing the dual drive kit?
Hello,
I have just ordered a dual drive kit and I have been skimming through the guide. I see the steps include the full tear down/installing the HD which is great. However there there are not steps for putting it all back together... Power supply/logic board ect.
Is there a guide out there for this or should I just try and work backwards through the original guide?
Many Thanks
Add a comment
Most Helpful Answer
All the iFixit install/replace guides are the same: Follow the steps to perform the disassembly/install, then follow the same steps in reverse order to reassemble the machine.
My own practice when I'm using an iFixit guide is to print out the guide (in color, if my color printer is working that day), and tape the removed screws/components to the pages at the place where they're removed. That way, I have the correct parts in the place in the guide where I'll need to reinstall them.
I was under the impression that Apple was using two drive bays in Fusion Drive installations: One for a standard 2.5" HD and one for an SSD. The Fusion Drive is then configured in software, through a tweaked version of Disk Utility to merge the two drives together into a single user-visible volume. Have you already taken the mini apart? Are you sure there's an empty space for a second drive? I would think that a Fusion drive installation would already have a dual-drive bracket in place, but both bays would be filled. Unless you're planning on converting to two SSDs, installing two drives would give you more storage space while losing speed.
My bigger concerns here are that:
  • The Fusion volume, although it uses two physical drives, is a single volume. If you remove one device from the set, all the data currently on the drive will be unreadable. If you separate the hard drive from the Fusion array, you'll have to reformat it in order to use it as a standard hard drive. If you want to keep your current data, you'll need to get it onto an external drive first - either using Time Machine, or cloning it using Disk Utility, Carbon Copy Cloner or SuperDuper!.
  • You may have bought a hard drive mounting bracket you already have pre-installed.
  • If your plan is to install an SSD in the normal boot drive slot, and a standard hard drive in the second slot, you already have that. If your plan is to install two standard hard drives, you'll gain space and lose speed. If your plan is to install two SSDs, there's a long history of quirky behavior from SSDs installed in the second slot of iMacs, laptops and minis.
What's your plan here? What are you trying to gain through this installation? If all you're looking for is more storage space, you might be better off with an external drive (Thunderbolt, FireWire or USB3). Since it's a desktop system, you can get a big 3.5" desktop drive, which are larger/faster/cheaper than most 2.5" HDs. If you're using an external drive, you can expand your storage just by attaching another drive when you need one.
Note: All these concerns apply only if you already have a Fusion Drive. Is that true? I suspect you can find out in several ways; Disk Utility should tell you whether a volume is Fusion-formatted, and the SATA section of System Profiler should identify the separate SSD and HD mechanisms, if you have them.
On the other hand, if you have a single drive mechanism and it's a Fusion Drive, I think a lot of us will be very interested to hear about it.
Score 1
Add a comment
Thank you very much for your detailed response. There will be plenty of tips I will be using.
Couple of responses to your questions.
The Mac Mini I will be picking up today currently has a 256GB SSD in it (standard from apple) so confident there is not a fusion drive in place..
I am buying this second hand from a friend so will be doing the usual hardware checks(Apple Hardware Testing)/re install mavericks first.
I will be adding a 7200rpm 1TB drive. This will be to create a fusion drive. I wont have any data on the machine as will be doing this work first.
I do currently also use external storage for a few things. A 1TB USB 3 drive purely for my video capture/iMovie editing. A 2TB USD 3 drive as a time machine and media storage. So I am fully aware of the benefits they offer. (currently using a 2012 MBA)
I have never taken a Mac Mini apart but happy with the look of the process and I will just take my time, take it slow and be careful.
Thank you again
1 Comment:
Once you've installed Mavericks/Yosemite, you should be able to configure your SSD+HD setup as a Fusion Drive just by using Disk Utility; you shouldn't need to fiddle with terminal commands like the rest of us. As iMacs and minis are the only systems Apple sells with Fusion Drives pre-installed, the build of Disk Utility that's installed on those systems is able to directly configure/format Fusion volumes. You'll still need to clone all the data off the existing internal SSD, if you want to keep it. Then boot from an external drive, configure/format the Fusion volume, install your OS, and restore the cloned data.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 163
