The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3691 Questions View all
Possibly shorted iPhone 5s battery connector, now it will not charge
So I probably messed up bad, but thought I would ask just in case....
I was undoing the battery connector from the iphone 5s logic board and, without thinking, used a metal spudger to do it and accidentally touched the metal rails that go from the connector into the logic board. I did see a small spark when this happened. After that, I put the phone back together and the phone would not power on. I plugged in the lightening cable and saw the icon showing that the battery was completely dead and needed charging, though before this happened it was around 40%. I then swapped batteries with a brand new one, and it powered on normally. However, the battery % will not go any higher even though the icon shows up when plugged in on the top right that show's it is plugged in.
My thinking is that I screwed up the battery connector on the logic board, is there any hope outside of replacing the logic board? And if a replacement is needed any advice on where to get a replacement would be much helpful.
Score 2
Add a comment
Most Helpful Answer
Cheap answer. But a battery and test it. More expensive answer. Send it to Jessa Jones. She can fix your current logic board, as opposed to buying a new logic board.
Score 2
Add a comment
I have done exactly the same thing. Probably just need a new battery and it will nee fully discharging and then charging up. Maybe the battery indicator has messed up.
I did the same on the iphone 5 I tried to press down on the cellular antenna but the battery connector is really close. I cannot see any black marks or any damage on the board so hopefully I have just blown the battery.
Score 1
Add a comment
Will Schmuck, this will depend on where you shorted out the components. Without proper troubleshooting, you are going down a wicked rabbithole. Check for any component that looks charred, missing or otherwise damaged. If you do not find anything you will have to have a meter, the schematic and will have to meter the components for shortcircuit etc.
Score 1
Add a comment
Add your answer
Will Schmuck will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 62
All Time: 5,028
