Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Why is my screen is black after replacing the lcd and digitalizer?
After putting the phone back together the screen is black. The vibrate function is working. I replaced the lcd screen and digitalizer on it because it got dropped.
Score 1
Comments:
hey man... im having the same probem.. did u happen 2 fix this ?
thanks in advance :)
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
The first course of action is to double check the display connectors. I know this sounds dumb, but you'd be surprised how often this can fix the problem. Which version of iPhone do you have (original, 3G, 3GS)?
Score 2
Comments:
it is a 3g and i did check the conections again and that didn,t help
by
Add a comment
if all is ok with the connection and the LCD. you certainly don't power off yr idevice when you open it.
1 dl Recboot
2 enter recovery mode
3 exit recovery mode
Comments:
can you explain your answer?
by
Don't know why but a recovery of the iphone fix this problem : black screen LCD when you put it on a iphone not plugged off.
For not lost data just turn your iphone into recovery mode and escape from recovery. (Recboot is perfect for that)
i have this problem on many iphone 3G, 3GS i've repaired and i have fixed this problem like this.
soory for my poor english
JC
by
just wondering why you don't have to power off? mostly black lcd recovers from a hard reset with home and power for 10sec. thought you might have a magic answer for why you needed to do the recboot...
by
Some time forgot to turn power off or put it on accidentally during repair.
The only reasons why i use recboot it's to not have to lost the data with a DFU.
by
Add a comment
Add your answer
lennox will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,392
