Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
I replaced my dock assembly, why won't my iPhone connect to pc?
whenever i plugged in my iPhone the computer said usb device has malfunctioned. i "googled" around for solutions and found i needed a new dock assembly. so i purchased 1 and installed it but now my iPhone still wont connect help please
5 Comments:
My iPhone would charge but there was no sound or lightning bolt when i plugged in in apart from 1 usb but i had the usb device not recognised problem. i changed the dock assembly and now ehen i plug it in there is no response from the iPhone or the pc. i havent checked if its charging should i let my battery drain to test for charging and then report back?
by
you don't need to discharge it completely - only enough to see the difference
by
well when i plug the turned off iPhone to the pc it turns on but ill check for charge asap
by
I discharged it an recharged it but when it's charging there no lightning bolt in the corner or "bleep" when i plug it in
by
do you still have the old dock assembly ? i would put the old one back into the phone - maybe the new one is faulty!
by
Add a comment
does it only not connect or do you still get the power surge error ??
if you still have that problem - open the phone again and check it for possible fluid damages, shorted or burnt parts..
2 Comments:
How will i know if parts have shorted?
by
if there was a fluid damage, you should see some white/greenish residue, but if it was some "colored" fluid - it could also look different (like the MacBook i bought on ebay with a blue curacao damage - everything was blue and sticky)
by
Add a comment
Before replacing the dock did you try connecting to a different PC I have had that error with a number of devices but it was caused by a faulty USB port.
1 Comment:
I tried on a friends pc and some macs in an apple store
by
Add a comment
I didnt see anywhere where i can comment or ask a question so i'm just putting it here. I was wondering if you ever found a solution to this darby? I'm having the same problem so i got a new dock connector and the problem persist. If you've made any progress please please please let me know!!! Thank You
1 Comment:
i did not make any progress as i couldnt be bothered to buy a new connecter from ebay just in case that doesnt work either. if i do end up buying 1 and progess is made i will reply with my results
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,053
