CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
422 Questions View all
My iPhone wont turn on it is stuck on the apple logo
i dropped my iphone in the toilet and it was working for awhile but then i turned it of to restart it but now it is flashing from the apple logo to black when it is plugged into the chager but when i take it off it goes black again.
Score 1
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
The inside of the phone probably has corroded a bit. Over time the corroded components and become more damaged. You would need to take it apart clean it with a toothbrush and rubbing alcohol. See if that fixes it. If not then you can see if one of the parts need to be replaced.
Score 1
Add a comment
need new battery also if its doing boot loop clean it with 70% acohol
Comments:
use air duster to dry it the reason you use acohol instead of anything else is acohol has a quick drying time
by
Add a comment
Add your answer
alie123 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 3,558
