Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
156 Questions View all
Question Closed
wont charge, will not power up
Why would a system not to power up with a charged battery? When I plug in my system to the charger, it will blink once in orange and then no light. Is it a F1 fuse, bad battery connector, bad charge port, or something else?
2 Comments:
did you get an answer?
by
not yet
by
Add a comment
Could be a charging port, if you have already checked to see if the port is damaged or loose..Try lifting the plug slightly up and then slightly down, If the orange light stays on steady when pressed upward or when downward.. then it's a port issue. But be gentle..It's a partially surface mounted plug.
Hope this helps...Let me know how it goes.
Add a comment
Probably isn't a wise thing to do but my port had that problem so when I got the orange light back I used the charger to righten it by pushing on it. If this isn't technologically wise someone warn other people off but I haven't blown up yet
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 591
