13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
589 Questions View all
What is causing flicker when screen is angled?
I am trying to diagnose/fix my rommate's issue. She has a 2008 aluminum unibody MacBook. When she moves the screen to a different angle, it flickers.
I believe there is a loose/faulty connection, but I don't know how to tell for sure.
Thanks for any help.
Add a comment
1 Answer
Chosen Solution
Yes it is a short
in the display data cable or the video cable. The cables run through the hinges and can be crimped or damaged. If still under warranty take it to a Genius bar, if not you (or someone for you) can use the guides here to see if parts need to be replaced or connections reseated.
'''If this answer is acceptable please return and mark it.
Good Luck,
N.
Score 1
Add a comment
Add your answer
Dani Fabulous will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 768
