The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 Questions View all
Question Closed
Will not agitate, drain, or fill
I have a Kenmore top load washer model 110.24642300. I loaded laundry, it filled, and went no further. There is no clicking or thumping noise when I raise or lower the lid. I tried unplugging in an attempt to reset the circuit, nothing. I've taken some water out and attempted to start a cycle again, thinking it would add more water, and nothing happened.
As the machine is not clicking or filling, I'm leaning towards the control panel being bad. I'm going to try to take the top off and take a look to ensure all electrical con tats are in tact, but do you think I am heading in the right direction?
Add a comment
1 Answer
Chosen Solution
Jacky, definitely worth a shot. The filling part is where I am stumped, but check your door switch and see if that works, Just use a multimeter and see if it closes the contacts.
Score 1
1 Comment:
You were right, it was the door switch. Very happy to say it worked,and I am back in the at home laundry business. Thank you for your help!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 457
