Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Questions View all
Speeds with Optical Drive swap for HDD
My Plan:
Take my Early-2009 iMac 24" 2.93Ghz 1TB HDD and swap it out with an SSD (at least 480GB) so that I am booting from a flash drive.
My Wish:
Remove the optical drive and replace it with the original 1TB HDD as a 2nd internal drive
My Concern:
  • Will that work? Does the original HDD fit?
  • Let's say it does fit, are the write speeds fast enough to justify not just popping the HDD into an exclosure for use as an external USB (2.0) drive?
  • IF the optical connector's write speeds ARE up to snuff, would I be better off installing the SSD there and using at as my boot drive?
Hope this all made sense.
Thanks in advance!
Add a comment
1 Answer
Chosen Solution
I think this is what you're looking for: iMac & Mac mini Dual Drive Enclosure
iMac & Mac mini Dual Drive Enclosure Image
Product
$19.99
Score 1
1 Comment:
Thanks mayer. But where does that leave me in terms of write speed as compared to using it as an external? Also, would it as effective/speedy enough to use an SSD there and designate it as the boot drive?
Thanks in advance!
by
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 143
