Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Questions View all
Question Closed
Why is my screen dark, but works with an external monitor?
I dropped my laptop and it cracked the screen and damaged the bottom left screen assembly housing. The laptop LCD was still fully functional and I used it without issue for a few days.
I took it to a shop to get a diagnosis and price estimate, I was told the screen/monitor/glass needed to be replaced, but due to the damage to the housing the entire display assembly would need to be replace.
After deciding to do the repair on my own, I retrieved my laptop and returned home. When I turned the laptop on the screen was now dimly lit but I could see the images with a flashlight. I order a display assembly and installed it (thanks to ifixit.com's guide).
Unfortunately, the dark screen issue still exists. I reset the PRAM & SMC. I connected to an external monitor and the laptop is fully functional. Also, I have turned the screen to maximum. My serial number is 7302105T7XJ.
All responses are welcomed, and any guidance is appreciated. Thanks.
2 Comments
Does the external monitor still work?
by
The laptop works with an external monitor and the lcd seems to be functioning other than the extremely dim lighting.
by
Add a comment
1 Answer
Most Helpful Answer
Joe Pierre, sounds like you are having issues with the LED backlight. This could be a bad backlight fuse, bad LED driver or power FET failure. You will have to take a closer look at the logicboard and check for damage. you will need a good multimeter for further troubleshooting.
Score 1
1 Comment:
Thanks! What is a considered a good multimeter? Also, where would I find a good tutorial on how to check the logic board? Thanks.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 359
