The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Questions View all
Question Closed
WiFi Doesn't Power On, hardware?
Model SM-N900A Firmware 4.4.2 baseband NC2
Been searching a lot of forums about this issue, Reinstalled the firmware and baseband, the only solution i've seen, is to send it back to samsung for a replacement, but thats not a solution, i want to try resoldering the chipset but not sure wich one is, or if anyone have another solution will appreciate.
Add a comment
Hi,
I am facing the same issue with my mobile, that its not applicable to enable the WiFi button on the mobile settings. I found that one Chip set was damaged because it heated to mush for some reasons which i don't know why!!
Please open the URL (https://d3nevzfk7ii3be.cloudfront.net/ig...), and the chip is located under the second highlighted box on the left side.. this need to be change.
Thanks,
Qosai
Add a comment
how do i fixt the my wifi?
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,095
