A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Questions View all
Question Closed
Replaced the battery with the ifixit guide, having real issues now ;(.
Hi,
A few weeks ago I ordered a battery from ebay (huge mistake) and replaced my old, worn out battery with the new one using the ifixit guide.
The new battery worked well for aroud one day and since then it drains extremely fast, causes extreme heat buildup, and the biggest problem is that when the phone is on, it takes hours upon hours to charge...
On top of all that, ever since changing the battery my GPS stopped being accurate, it can tell where I am approximatly, but apps like waze or maps wont work...
Is there anything I can do to save the phone?
Thanks!
3 Comments:
No help at all?
I am desperate...
by
replace the battery once more with a new one and reevaluate. Could be a battery issues but could also be a power management IC issue.
by
What could be the cause of the GPS problem? I screwed up the gps antenna? Weird... it seemed to connect OK...
How can I repair the GPS?
by
Add a comment
Did you check the battery temperature? I currently have an issue (and as yet unanswered question) that really charges slowly if at all when the temp marks as being -30 degrees C. Apparently, the phone won't charge the battery at certain temperatures
Add a comment
I think we have a similar problem...
Hardware Charging problem-- over heating
what did you to fix this ??
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 222
