The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3399 Questions View all
My iPhone 5/5s Cracked during repair
during repair, the iphone doesn't fit completely in the top (second image) and when I try to push in the iphone in, it cracks (seen in first image) why does this happen? is there any way to fix this? It happens on both 5 and 5S
Add a comment
Chosen Solution
The screen will fit if the frame is square---assuming it is a quality part.
I've had that happen on the first 5S I did. Every time after that I really try to press the bottom of the phone into the top of the frame as I'm fitting it---never happened again.
Score 1
Add a comment
It's important to make sure all four corners are shaped correctly for the screen to fit, as they are often bent when the phone has been dropped. There are tools for shaping them (G-tools for example). A file can be sufficient sometimes.
Add a comment
Add your answer
TajAtassi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
