Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
How do I fix a sticky keyboard?
I spilled some soda on my keyboard..everything works fine but some keys (and the space bar) are sticky, and it's a pain to type on. How do I fix it?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
you can try carefully removing the affected key caps, then use a q-tip dampened with alcohol to clean the residue from the under the key. Don't forget to clean the underside of the keycaps as well.
Score 2
Add a comment
Take a can of compressed air and spray all around (and under, you don't have to take them out) the keys.
Add a comment
I've done what David suggests many times. Compressed air will not remove soda syrup. Direct access is the only way.
Comments:
If it's dried and hardened it will remove hardened soda particulates.
by
Add a comment
Add your answer
eam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 4,290
