Introducing the Dell XPS M1530, a sleek and powerful multimedia machine expertly balancing performance, design and unprecedented functionality.
11 Questions View all
Question Closed
Disk is stuck inside the optical drive
A disk is stuck inside the optical drive of my Dell M1530 laptop.
How can I remove the disk out of my optical drive??
The use of the eject button has no result.
I have to mention that the M1530's optical drive is a "slot" type drive.
Add a comment
Most Helpful Answer
See this previous answer.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Thanks a lot machead3 for the answer!!!
Your solution is brilliant.
But, I managed to solve the problem using my own way.
I used my metallic spudger in order to push the disk a little bit downwards (somewhere in the middle of the slot) and the optical drive did the rest. The mechanism worked and the disk came out.
Problem solved the easy way.
Thanks again.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,924
