Repair guides and support for all types of building materials.
189 Questions View all
need to remove hold down nail without damage to metal roof
How can I remove the hold down nails {to be replace with insulated screws[from the corrugated metal roof
without damaging the metal roof? is there a nail puller
that pulles straight up and not pried up.
Add a comment
1 Answer
Chosen Solution
You may need to fashion a block of wood that conforms to the metal roof to spread the pressure of the hammer claw/crow bar base as you pry the nail.
I took two blocks of wood and two pieces of 1/4 steel placed across as short a distance as I could between the blocks. Then resting the hammer on the metal bar pulling the nails.
In my case I had raised over-lapping seams. If you have corrugated roofing that will be harder depending on where they nail it down.
Score 1
Add a comment
Add your answer
R Klein will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 100
All Time: 4,718
