Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Question Closed
No Power, Diag LED #4 briefly lights...How test Pow Sup and MB?
Dead IMAC.....is there a procedure short of replacing the power supply and the logic board?
Once you remove the LCD, you can see the 4 diagnostic LED's on the Logic Board.
When I apply AC power, LED 4 breifly lights up and then goes dark. The Start button does nothing.
Is there a way to test the Power Supply?
How do I know if this is a Logic Board issue?
I bought this with a known issue and no ram and no Hard Drive.....silly me.
Add a comment
1 Answer
Chosen Solution
You'll need to install some ram to start with and either have a OS installer disk or have a bootable thumb drive/HD to run the system.
OK, so assuming you have the bare minimum required to run the system here. I wound inspect the LVDS cable and the horz. sync cables make sure they are not damaged also check the connectors as well. Your symptom sounds like something is shorted.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 157
