A point-and-shoot digital camera by Panasonic identifiable in North America by model number DMC-ZS7
11 Questions View all
How to fix a lens that is won't open?
Anytime I turn my camera on it comes up with "system error zoom". It was working perfectly fine then the zoom started acting a little shaky when it was coming out... not being able to focus or zoom long distances or macro shots, then it just stopped opening. I am afraid to take it to a camera repair shop as they usually cost tons of money of which I don't have..... Any help with this would be greatly appreciate. Thank you :)
I have almost the same issue with a DMC-ZS6.
Do we have someone to help with this?
Thank you in advence.
Add a comment
Chosen Solution
Scarlet, " little shaky when it was coming out" sounds like debris between the lens rings. Start by using a vacuum cleaner hose and see if you can get the lens somewhat cleaned. Check on here for some more ideas. If that does not work, you may consider replacing the lens. hope this helps, good luck.
Score 2
Add a comment
Yes that's a big problem
Add a comment
Add your answer
Scarlet will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 162
All Time: 6,234
