Computers that generally don't include an integrated display, and are meant to be stationary.
2133 Questions View all
Question Closed
Why Windows Explorer hangs when opening or changing a folder.
Using Windows 7 Pro, when I try to open a folder or pick a folder using SaveAs I get a (Not Responding) comment and the system hangs for about 45 seconds. Once the folder is open, I can navigate to other folders in the window without the hanging.
Add a comment
Chosen Solution
Your HD is failing. Often this is a sign of the directory tree being corrupted. Make a backup of your files ASAP. You'll need to reformat the HD and test it to make sure it can still be used. If you have a drive that is running out of space you might just want to upgrade the HD.
Score 2
1 Comment:
If this answer answered your question please remember to rate (score) and mark it accepted.
by
Add a comment
Thanks, I half suspected that because I ran a diagnoistic that said I had a HD problem.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 986
