Repair information and guides for MacBook Pro models with 13" displays.
9739 Questions View all
Burned integrated circuit on motherboard, related to power supply
hi,
i've got a 2011 macbook pro 13" with a big problem: i've found a damaged integrated circuit on the motherboard, (i think related to to the power circuit, because it doesn't turn on and there's a faint green light on the connector of the power supply when connected). I post a photo of the damaged part, in order to know the identifying code of it, and maybe you can give me some help to find it to replace it. Thanks in advance.
Add a comment
1 Answer
Chosen Solution
sandro859, that is reference designator Q7035 which is a RJK03E1DNS Silicon N Channel Power MOS FET. Read the datasheet on here. Check Digikey.com or Mouser.com for availability. BTW even Ebay.com seems to have a supplier:-) If you are doing a global search check for a MOSFET N-CH 30V 25A 8-HWSON. Hope this helps, good luck.
Score 3
Add a comment
Add your answer
sandro859 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,142
