Fix Your Stuff
Right to Repair
Store
Repair guides and support for cars manufactured by Jaguar.
22 Questions View all
The driversdoor doesn`t work
where can I find the driversseatmodule to change it ?
is in the door or near the engine ?
thanks . peter
Comments:
what model is your JAG?
by
Add a comment
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
sorry . i forgot it . it is a XK8 from 2001 .
thanks . best regards . peter
Add a comment
Its under the seat, attached to the seat itself. By far the easiest way to get to it is to just take the seat out (undo the 4 big Torx bolts, one at each end of the 2 seat rails, then undo a connector to disconnect the seat wiring). You need to move the seat forward and back to get to all the bolts so leave the connector till last. Other than that its a no brainer and takes about a minute.
Add a comment
Add your answer
peter raab will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 315
