upgrade my HDD from 1TB to 2tb
I would like to upgraded my HDD from 1TB to 2tb for Mid -2007 24inch EMC 2134. It is possible?
Yes & no - While the OS can support the larger sized HD. Your system has an older SATA port, SATA I (1.5 Gb/s) most of the larger HD's have a much faster SATA speed SATA III (6.0 Gb/s). So you'll encounter problems if you're not careful. I would recommend you go with a SSHD unit vs a straight HD here as they often can support the older systems. As an example Seagate's SSHD would work here Seagate desktop SSHD's.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 149
