Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Questions View all
Swap display between 2011 & 2012 MacBook Pro?
Hi there!
Basically what I want to do is to take a high-res glossy(!) display from a primo 2011 Macbook Pro and use it as a replacement for the standard res screen on a mid 2012 Macbook Pro. Is this possible?
From what i've read its seems possible I'm not sure if the connectors will match.
Add a comment
Most Helpful Answer
100% works, "but". Typing this on a 2012 MacBook Pro unibody 15 with a 2011 Unibody 15" high res matt display and top case.
The keyboard failed on mine, so I swapped the display and top case (and went for the upgrade along the way as a toasted 2011 model wasn't much more than a top case).
The "but" is that the connector is slightly different. The wiring is identical, but you have to bend (not break!) the tabs at either side of the connector on the logic board, which is a delicate job. The connector then slots in and locks into place as expected.
Score 2
Add a comment
Parts catalog says won't work.
11's fit only '11s - 12's fit only 12's.
If this answer is acceptable please remember to return and mark it.
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly Image
Product
$149.99
Score 1
2 Comments:
I know it says that in part-list in here but I have read about others who've done this successfully.
by
I'm confused. You already knew the answer but asked a question about it anyway? Then you should ollow the direction of the others.
by
Add a comment
Add your answer
Thomasgd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 885
