Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1438 Questions View all
Power button & "jumpstarting" no longer working to power on or off..
MacBook os x 2.4ghz intel core duo 5gb 1067 mhz ddr3
My macbook didnt power on by using the power on button when I got it but i quickly learned about the option of whats known to be called "jump-starting" it... that was going fine to boot it up for a few weeks, no problems with doing that whatsoever. However, now that has stopped working as well to turn my macbook on and off. when its plugged in, i do get the green "charging" light that comes on but nothing happens by using the power button or "jumpstarting" it..... PLEASE HELP!!
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Disconnect the top case ribbon cable to the logic board and check the voltage on the power pads. You should get 3.42 volts on one of the two pads, thats the voltage needed to power on the logic board. If you don't get the good voltage (even if the magsafe tip light is alive) there's a problem down the power line (G3 hot rail) somewhere on the logic board. Was this macbook liquid damaged ?
Score 2
Add a comment
Add your answer
jar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
