1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
256 Questions View all
After turning the iMac on, all I see is blue.
After the power went off one night I tried restarting the computer the next day and it went smoothly past the first part where you see the apple but right afterwards it came to a blue screen and that's how it stays.
I've tried turning it off and turning it back on but that didn't work. I also tried leaving it for a few hours but all it did was flicker to a light blue then a faded blue.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Sounds like it corrupted the system software. Try holding down the Shift key on start up. Next startup from your original system installation disk, hold the C key down. Run Disk Utilities on the hard drive and repair it then give it a try and let us know your results.
Score 1
Comments:
It worked!
Thank you so so so much!!
by
If you accept this answer it can be used to help others.
by
Add a comment
Add your answer
Jasmine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 62
