Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3267 Questions View all
Changed screen. Now won't start properly. Showing codes at startup.
So I changed the screen. Prior to this the phone was working. Now at startup, the logo is shown as usual for a few seconds. Then the logo turns grey and I get codes from the top of the screen. Nothing happens after this. What should I do?
Score 2
Add a comment
Hello disconnect the frint camera cable and turn on again see does that fix it..
Usually a faulty camera flex causes this fault
Comments:
Tried it, nothing... Anything else?
by
Can you post a pic of the codes?
by
Add a comment
There is three cables connecting the screen to the motherboard. Try disconnecting them, then reconnect them. Did this work?
Comments:
Nothing special happened. Tried disconnecting the battery as well. Nothing.
Seems like if the screen I got was a used screen. Had a lot of scratches like from keys...
Is there a possibility that a cord could be broken without being visible, and that that could cause this problem?
by
Add a comment
Add your answer
gustaf stangel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,397
