Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Extremely poor wi-fi reception tried a lot
The wifi on my iPhone 4 is extremely poor, i only get my own connection with 1 bar if i'm next to the router.
The antenna has already been replaced, and that seem antenna was tested in an iPhone 4 where it works, what could be the solution :(?
Score -1
1 Comment
I tried cleaning with isopropanol and it did not work :(, ofcourse the antenna is allright i tested it on different iPhones where it all works fine.
by
Add a comment
Most Helpful Answer
You probably didn't put the black cover (the emi shield that covers the top area.
Make sure you put it on and there should be a clip at the top part of the cover. You have to put a screw through this clip which will make a ground connection with the wifi antenna and boost your signal
Score 1
Add a comment
Maybe you forgot the tiny metal washer. It's important for wifi and GPS signals.
Add a comment
Add your answer
Frank Buurlage will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
