engine dies when I let off gas pedal?
Must push gas pedal down to start. Will start and run untill I remove my foot from gas pedal.
Brad Klopfer, this could be caused by a bad idle air valve. You could try and removed the Idle Control Valve clean the carbon out of it and see if that makes a difference. If not, I would replace it and see what happens. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 841
