Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1500 Questions View all
What is the the mainboard chip/part in the picture (USB?)?
I have an iPhone that someone else tried to fix, but the part circled was destroyed and replaced by solder blobs by them. The USB port isn't working, so I think is either a fuse or USB protection device of some kind. I am hoping if I replace it, or at least clean the solder mess they left that the USB will work and the iPhone will no longer be a brick.
http://s1006.photobucket.com/albums/af18...
Update
I found the answer elsewhere, the part is a noise filter for the USB data lines, and I bypassed with wire links on the PCB pads. That got the phone working fine with iTunes. The actual part is a Panasonic EXC14CE900U according to what I found.
Comments:
I noticed you never got an answer to this. Are you still having this problem?
by
any chance you could provide a link so others can find the solution too? it'd be great help. cheers, jen
by
Please provide a link and accept your own answer so this post can be archived and help the next person with similar issues.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Here's a link showing the fix:
http://forum.gsmhosting.com/vbb/f631/iph...
I used a single strand of wire taken from an old hard disk ribbon cable - the pads are really tiny so you need really fine wire (and a fine tip solder iron).
Score 4
Comments:
Please return and accept this Answer.
by
+ very good
by
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,863
