PSU probably dead, please help diagnose if logic board is working.
Hello everyone,
my iMac has died this morning and caused short circuit in my home's power installation. First, I thought that a power surge has blown out the PSU in the iMac, but it turns out it was the other way round. Upon inspection of the iMac's PSU with multimeter I discovered that the 250V 6.3A fuse in the PSU was blown, and, thinking that the power surge was the cause - I've soldered new fuse and put the iMac together. When I plugged the power cable to the wall outlet (iMac turned off) - fuses in my home power installation had blown again, and this indicates that the iMac caused the first power surge as well.
I have taken the iMac apart again - the new fuse in the PSU doesn't seem to be blown (I get a reading of few mOhms in it) and voltage reading between fuse legs is 240V, but the computer is still not starting. Connecting it to wall outlet doesn't cause short circuits anymore. I have checked voltages on the PSU output - there is no 12V line. There are two pins that read 1.85V between them and GND pin.
I have checked most diodes and capacitors and they seem to be working fine when desoldered from the PSU, but when they are connected to the circuit - some of them seem read short circuits on my multimeter.
Is there any way to check if it's the PSU that has shorted out in the first place? Is it possible that something has blown up on the logic board and caused a short that would damage the PSU as well?
Can I somehow check for shorts by testing pins on the cable that goes from PSU to the logic board? Does someone know the correct pinout of this cable?
I would appreciate any help!
