Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
508 Questions View all
Nokia Lumia 820 LCD replacement, which glue and copper foil?
I (perhaps foolishly) volunteered to replace the LCD on my friends' Lumia 820. I did some research beforehand but failed to notice that the LCD in the phone is glued to a metal plate with a layer of copper foil in between. The replacement LCD I bought does not include the plate or foil.
You can see what I mean in this video https://www.youtube.com/watch?v=CFz3-Hh9...
I wasn't as successful as the guy in the video and completely destroyed the copper foil.
So what I need to know is:
What can I replace the copper foil with? There's lots online but I don't know if I need something special.
What glue should I use to glue the LCD, copper foil and metal plate back together? The research I've done suggests silicone based glue but I don't know which one.
Thanks.
Score -1
Add a comment
1 Answer
Chosen Solution
Hello James, Tough luck :/ sorry for you,
I am not 100% sure but I think it would be ok to just put them back together, but at least using a double tape in between,
Otherwise you could purchase for around 10$ the whole plate with this famous copper layer Found this here --> http://www.ebay.com/itm/Housing-LCD-beze...
Or here ---> http://www.etradesupply.com/oem-nokia-lu...
I would use glue because its easyer to apply, using a silicone based glue should be more than enough for this method, for the first one without this copper foil I would try a double side tape.
Cheers, I would pay 8 bucks and do the second, now its up to you.
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,232
