Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
No backlight after complete Touch/LCD replacement?
I repaired an iPhone using a complete Touch/LCD and the phone seems to work except for the backlight. As there is only three cables from the screen to the rest I wonder which one of these that powers the backlight?
Second question could of course be - is there any risk that I damage something else during the process that could effect the backlight?
Add a comment
Chosen Solution
hi peter, i edited your post - i think that "LSD replacement" is something different ;-)
the backlight and the lcd are powered by the same connector (1)
to the second question:
did you remove the battery while installing the lcd ?
if not, sure - it's possible that you shorted something
i only see 3 possible faults:
  1. the connector isn't plugged in correctly
  2. the backlight of the lcd does not work
  3. the coil for the backlight died while the connector shorted the contacts
Score 2
Comments:
Where is the "coil for the backlight"?
by
I think you mean that coil and fix?
http://img686.imageshack.us/img686/9351/...
by
Add a comment
If your iphone screen was working (backlight) prior to screen change then a short has occured and the coil is fried. Check out 'backlight coil replacement 3gs' (and other combinations) on ebay -there are guys who will fix your phone for £20.
Add a comment
Add your answer
Peter Karlberg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 27,111
