Water Damage. SSD only half storage
Hi everybody,
I got this water damaged device (MacBook Air 11" Mid 2011). A glass clear water run through it, I let everything dry but it wont do anything.
I already took it apart und cleaned all parts with 96% alcohol. The macbook starts and shows flashing folder icon. So it tryed a clean install from usb. I see the internal ssd, but it only gots 60GB, it should have 128. I tryed installing Mavericks to it, but it alwas breaks saying "cant install recovery partition". I then try to install a windows 7 on the ssd, it got a error too.
Right now I'm typing from the water damaged air! I install Mavericks to a usb device. Everyting works fine, all tests were fine. Only Problem ist the ssd. I double cleaned it with alcohol, I baked it in the oven for 7 minutes...nothing...it still reads only 60GB und I always got an error trying to install an OS on it.
Any idea what to do or should I just order an owc ssd? I thing it cant be a problem of the logicboard, must be the ssd itself.
Another problem is the keyboard. Everything works like it should, only the key "6" istn working. I know thats it possible the take out only the keyboard itself, without replacing the whole case. Should I try to clean the keyboard contacts or just replace it?
The bigger problem is the ssd, cause I need to spend 100 bucks for it...anyone ever got this problem after a water damge?
Thank you guys in advance!
