Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
875 Questions View all
Lawnmower shut itself off while running. Does not start.
After a long run, noticed a white smoke coming from the muffler and then the engine stopped. I let it cool down, checked the oil, and replaced the sparkplug. None of these helped.
Score 1
Comments:
Can you give a description of what exactly it does when you try to start it? Does it do nothing? Does it attempt to start and then cut out?
by
Add a comment
1 Answer
Chosen Solution
Try a compression check. It sounds to me like you blew a head gasket or maybe even the head.
But look here too.
-OR-
The case could be over filled with oil.
The rings could be worn depending on the age/hours.
White Smoke not good, sorry.
Frank
Score 1
Add a comment
Add your answer
petruchio55 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,687
