Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
174 Questions View all
Is the inside of the MacBook the same as it's previous model?
Is it better to upgrade/repair the Macbook than the Late13 model? What about the SSD, still the same? 1 Fan or 2 Fans again? And is the battery still glued to the case?
Cheers!
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
It's to soon to say what Apple did internally until someone does a teardown.
From what I understand Apple only did a slight speed bump on the CPU's
As to upgrading, if you have last years (Late '13) I don't see any benefit with what has been disclosed on the Mid '14 models. Opening the system up to swap things would be more costly and it will be awhile before the parts are even available (besides the risk of damaging your system).
If you really want the latest system, sell yours and buy a new one boxed!
Score 2
Add a comment
Add your answer
Lukas Bonny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,045
