Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Motherboard/camera malfunctioning, after bad repair.
Ok.. first of all - i did a bad repair on my own iphone, i was sleasy and too fast, and - it was my first time trying. But!
After the repair, i found out, that my front camera was not working, and i might have ripped out a small chip(doh). - ok, a bit annoying, but i can live without selfies.
But after 3 months, the other camera stopped working aswell! Which is a bit more annoying!
I have ofc. done the basic troubleshooting, by resetting the phone etc. All though, i haven't opened the phone yet, because of the mess i did the last time i tried. :-)
Anyone have any advices? I know the frontcamera is pretty much done for, it stopped working right after i turned on my phone, after my bad repair. But the other camera?
P
Score -1
3 Comments
what repair did you do?
by
i changed the screen.
by
Update:
The flashlight does not work, not in camera app and not when i want to use it without.
by
Add a comment
Most Helpful Answer
By resetting, do you mean that you went to settings--general--reset all settings?
This will reset the camera app. The camera app can sense a hardware defect in the front camera and will shut down and not operate either camera. You can live with this by never engaging the front camera. If you do accidentally, then a reset as described will bring back rear camera function.
Otherwise, you have to 1) reseat. 2) replace both cameras, and if not solved send out for board repair. If you can see visible pry damage on the logic board, it can most likely be fixed.
Jessa
Score 1
2 Comments:
I have already done the first part. There is something wrong with both cameras. :(
Thanks anyways! :)
P
by
More likely board damage than both cameras failing.
by
Add a comment
Hello Peder,
I would start by trying to replace the front camera. You very easily might have tore the flex cable. So start by trying to replace this. Also this might sound crazy but perform a soft reset and then from the lock screen pull up to enter your camera. As quick as you can hit the flip button. This will sometimes kick the rear camera out of its funk however it will not fix the front camera.
Hope this helps!
1 Comment:
Looks like i have to open the thing up again. :/ Im sorry, that your little trick did not work - that would have been nice!
Thanks for the advices.
by
Add a comment
if you changed the screen and all these things are happening my guess is when prying off the connectors you broke off some of the small components around the front camera connector and elsewhere. Your going to have to open the phone back up and look under magnification for missing components. If you have any experience soldering small parts its not a hard job, and the parts can be found on digikey. Use an iphone 5 schematic to identify the correct parts.
Add a comment
Add your answer
Peder Helms will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,274
