Keyboard and track pad doesn't seem to be seated properly
After loosing the screw set for the bottom part of my mbp, it stayed like that for several months.
I now bought a new set of bottom screws but now, the keyboard seems to not seated well, only in the bottom section near the track pad.
That whole line of keys, including the Enter key just doesn't click properly, noisy when pressed and seems to have hard time clicking in and out.
Same issue with the track pad too, clickin is proplematic.
Batery is playing up too... it doesn't get charged when left on charge, SMC and/Pram reset few times and it works again, only to stop charging again later
2 Comments
Can you give us some history on what you did here. It sounds like you replaced the keyboard and trackpad is that correct?
by Dan
Yes.
Water spill then it stops working.
When it was given to me, the mbp was totally irresponsive. No light or sound.
I removed the bottom case to take the hdd but then lost the screws. So the mbp sat on the shelves for quiet some time as is.
Jus two weeks ago, I tried smc and pram re settings (again!!) and... voila! It worked
I don't know how or why but it came back to life.
However, I've noticed the keyboard and trackpad seemed stuck and weird squeezy noises when pressed. So after purchasing the bottom case screws, the problem is a bit better but still there, this time only the trackpad and the bottom line of the keys (ie Shift-Cmd-zxc....,. )
by hasanito
