Why would my mac powers on then shut off
I purchased an 08 15" macbook pro. It powered on but then shut off. I took it home took it all apart, found a small amount of corrosion on the bottom side of the board. soaked in alcohol and fully cleaned the board, let it dry put it back in and it does the same. I found that if i leave the lcd cable to the board unplugged it fully boots up and i used it with the external port fine. Tried another lcd and does the same. Is the pin connector bad or something else? The connector on the logic board looks fine and the corrosion was on the bottom under the speaker. Any help appreciated.
