The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3612 Questions View all
iPhone 5s home button works after repair but touch ID doesn't?
Hello,
Thank You for taking some time to help me with my problem, after replacing the screen on my iPhone 5S the home button works but touch id does not (the option has disappeared from settings).
Any help would be appreciated
Jordan
Score 1
Comments:
And the cables don't appear to be damaged.
by
Did you keep the same home button flex? Try a hard reset.
by
Add a comment
Most Helpful Answer
ive had this happen before aswell, try a soft reset, that worked for me (home button and power button till phone turns off)
Score 1
Comments:
Thank you for the suggestion, I've already tried that and a backup and restore.
by
Add a comment
my issue is the other way around. home button wont work but my touch id does. any ideas on how to fix this? also i have no service after the screen replacement as well.
Add a comment
If your touch ID is not showing as an option in your settings then you damaged the home button flex cable. You will need to take the iPhone to Apple for a replacement.
Add a comment
I did and I got a replacement iPhone at no extra cost.
Add a comment
Add your answer
Jordan Baker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,020
