LCD brightness flickers when moving the monitor - How 2 fix?
When I open the monitor, it feels like there is a "short" in the power supply to the LCD... as I move the monitor, the brightness flickers dark / light until I stop moving it. I have to wiggle the monitor to get it to display bright or move it into a different position. The hinge also feels very loose inside. I want to know...is there a ribbon cable in there that may be damaged / pinching? Can I buy from you and replace it myself and tighten the hinge as well?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would make sure to replace the inverter cable before it shorts in the hinge and damage the logic board. Meanwhile don't play too much with the lid.
Score 2
Comments:
agreed +
by
Add a comment
I'd suggest an issue with the inverter cable. It's located at the left hinge.
Score 1
Add a comment
Add your answer
Joey Morelli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,199
