The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
108 Questions View all
Ways To find out damaged PCB?
When the phone is put on charge, the charging indicator lights up for about 2 seconds before goin off. The screen does not turn on. So is there a way of finding out if the PCB is damaged other than replacing one?
Comments:
What have you tried so far? Does it charge your battery?
by
I feel the battery getting a bit warm after about 10-15mins of charge time. But since the phone doesnt switch on, i cant really see if the battery is getting charged or not.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
farhan, start with a new battery. That will give you a known-good part for further troubleshooting. It could be the charger, the cable, the charging port or the charging coil on the logicboard as well as a firmware issue....start simple and work your way up. Hope this helps, good luck.
Score 1
Comments:
thanks.. will try that and see how it goes. and what if the charging coil on the logic board is damaged?? is there a way of replacing only that?
by
Add a comment
Add your answer
farhan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 651
