1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
253 Questions View all
Replacing iMac 17" Hard Drive
I understand the physical process of replacing the hard drive. My question is how difficult it will be to move my content (including programs and data) to the new hard drive once it is installed?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You should first make a backup of anything important onto an external HD (FireWire if you can find one).
Once that is done you typically connect a universal adapter via USB to your new HD. Then using some cloning software copying over to your new drive what you have. Then you check the new drive to make sure it boots up your system. Then you swap over the drives.
Score 1
Add a comment
Add your answer
steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 65
