A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. Released August 2012, repair of this device is straightforward.
133 Questions View all
broken charger connecting(micro usb) port.
my galaxy note 10.1 is not working because it was broken micro usb port for charging. so where can I repair it in anchorage? or how can I repair it in anchorage?
Score 1
Comments:
Good information here on teardown but does anyone have a suggestion on where to order the replacement port/dock connector? I've looked and I'm getting flooded with 2014 model info. Mine is the 2012 version. Thanks for anything you can share to help.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Most Helpful Answer
Hi,
The charging port isn't soldered to the main board. Replacing is easy, because the charging port is on the flex cable. Look here step 15, pic. 2
Samsung Galaxy Note 10.1 Teardown
But you must have some experience to disassemble the Touch screen & LCD display module. It's held by screws and clips.
Regards.
Score 1
Add a comment
Add your answer
enginekd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 5,044
