The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Questions View all
Power Board Connector Ripped Of From Mobo (w/ pics)
Hello,
While I did find a couple questions similar to this one, my head hasn't come around a clear answer. I was at the process of fitting a new touch-screen on my DSi and I've accidentally popped open the Power Board Connector straight out from the Motherboard. Ignoring the problem temporarily, I continued on fitting the touch-screen in which was placed successfully. I refitted all the ribbon cables and the screws back on the motherboard, but I'm left with the broken connector.
The cable should have been disconnected from the connector like this:
Using a tool like a Spudger
And opened like this
Alas, mine has become like this (excuse the poor quality)
So I believe the two options I may have is to solder (?) the connector back onto the motherboard OR buy another power board altogether (I would be more comfortable with that). However, I'm not sure if that little casing for the cable comes with a standalone power board connector; so that option will be crossed off. All in all, I would highly appreciate if someone dusts off the confusion!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Elias Raed, your picture is very hard to interpret. If you broke the connector of the board you will have to either solder it back on (depends on the condition of the traces.) If you broke the plug you will need a new power board. Hope this helps, good luck.
Score 1
3 Comments:
Hello oldturkey thanks for the fast response!
Unfortunately, I did think the picture was too blurry and I cannot get a decent close up. But what you stated was correct. The whole connector is disconnected from the motherboard.
The part of the logic board and the part of the power board is still connected together, but isn't on the motherboard. I do believe the traces are still in good condition and possible soldering is at need. In the meantime, I'll have someone look at this and will update ASAP.
Thanks
by
Alas, there was a mistake on the comment before. Sadly I can not see any metallic traces on the body of the white socket (which sits on the motherboard).
by
Soldering the wires without the connector should work.
by
Add a comment
Add your answer
Elias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 302
